Backup of import fails
TobiasMadsen
Post by TobiasMadsen » 18 Dec 2020, 10:07
Hi Aimeos :)
I'm importing categories (and after that, products - question is the same), but get the following fail:
Aimeos\Controller\Jobs\Exception
  Unable to move imported file "imports/categories/toimport/" to "imports/categories/imported/imported_18-12-20.csv"
  at C:\laravel_webshop\ext\ai-controller-jobs\controller\jobs\src\Controller\Jobs\Catalog\Import\Csv\Standard.php:378
    374▕
    375▕                if( !empty( $backup ) && @rename( $path, strftime( $backup ) ) === false )
    376▕                {
    377▕                        $msg = sprintf( 'Unable to move imported file "%1$s" to "%2$s"', $path, strftime( $backup ) );
  ➜ 378▕                        throw new \Aimeos\Controller\Jobs\Exception( $msg );
    379▕                }
    380▕        }
    381▕
    382▕
  1   C:\laravel_webshop\vendor\aimeos\aimeos-laravel\src\Aimeos\Shop\Command\JobsCommand.php:76
      Aimeos\Controller\Jobs\Catalog\Import\Csv\Standard::run()
  2   C:\laravel_webshop\vendor\aimeos\aimeos-core\lib\mwlib\src\MW\Process\Decorator\Check.php:63
      Aimeos\Shop\Command\JobsCommand::Aimeos\Shop\Command\{closure}(Object(Aimeos\MShop\Context\Item\Standard), Object(Aimeos\Bootstrap), "catalog/import/csv")
The category gets imported as it should but the backup fails. My shop.php is like this:
'catalog' => [
                'import' => [
                    'csv' => [
                        'location' => 'imports/categories/toimport/',
                        'backup' => 'imports/categories/imported/imported_%d-%m-%y.csv',
                        'skip-lines' => 1,
It is probably something stupid, but i just can't get it right!
For your reference; Folder structure is like picture attached. The "imported" folder is empty
folder backuo.png (2.1 KiB) Viewed 2898 times
Re: Backup of import fails
Post by aimeos » 20 Dec 2020, 13:00
Most likely, it's a permission problem. Your cronjob is executed as another user than your web server, so check the permissions of the backup directory.
TobiasMadsen
Post by TobiasMadsen » 20 Dec 2020, 15:47
As of now i am running the command directly from terminal.
I have tried both locally on my Win10 environment and on the Debian server (with www-data as owner of folders). On the server it works, so thats fine.
Thank you for your response :)
