Attribute sorting [SOLVED]
goransabo
Post by goransabo » 19 Dec 2020, 11:48
Hello!
I have one problem with attribute sorting by position or id!
ID and pos (in db) is correct, but on frontend attributes have incorrect position!
Screenshot in attachment!
Best regards,
Goran
// Typo3 10.4.11 / Aimeos 20.10.4 / PHP 7.3 / Linux //
Re: Attribute sorting
Post by aimeos » 22 Dec 2020, 11:06
What's the sorting in the attribute subpanel of the product?
goransabo
Post by goransabo » 22 Dec 2020, 12:09
in frontend sorting is incorrect!
goransabo
Re: Attribute sorting [SOLVED]
Post by goransabo » 22 Dec 2020, 19:43
Here is fix for the problem with correct sort of attributes on product detail page:
In Resources/Private/Extensions/ai-client-html/slient/html/templates/common/partials/attribute-standard.php you need to find 131 line:
<?php if( $this->config( 'client/html/catalog/attribute/preselect/' . $code, false ) === false ) : ?>
<option class="select-option" value=""><?= $enc->html( $this->translate( 'client', 'none' ) ); ?></option>
<?php endif; ?>
add this: <?php ksort($attributes);?>
<?php foreach( $attributes as $id => $attribute ) : ?>
<option class="select-option" value="<?= $enc->attr( $id ); ?>">
<?= $enc->html( $this->attrname( $attribute ) ) ?>
</option>
<?php endforeach; ?>
Post by aimeos » 24 Dec 2020, 09:07
The attributes are sorted by the order you have added them in the product detail panel of the admin backend, not by the position of the attributes themselves. Thus, you can have a different sorting for different products.
