Create a new site based in custom extension
saqibsaud
Post by saqibsaud » 22 Dec 2020, 06:42
I have created a custom extension through https://aimeos.org/extensions and copied it to the ./ext directory.
Then how to load a new site based on this extension name?
I'm using a different layout and structure for the e-commerce frontend of our site.
Re: Create a new site based in custom extension
Post by aimeos » 22 Dec 2020, 11:15
An extension per site isn't supported by Aimeos.
We will check if we can support different themes per site in the future (CSS/JS only).
saqibsaud
Post by saqibsaud » 29 Dec 2020, 10:06
ok, thanks...
Where do I have to overwrite the existing templates and point the frontend to an updated one?
Please help me out....I'm really stuck in editing the frontend template...
Post by aimeos » 30 Dec 2020, 14:58
There's documentation for creating new themes and overwriting templates:
https://aimeos.org/docs/latest/frontend ... te-themes/
