Problems with bootstrap package
TheDarkBlueEvil
Post by TheDarkBlueEvil » 03 Jan 2021, 16:31
Hy Guys,
i use Typo3 in version 10.4.12 with bootstrap package 11.0.2. My installation are powered by Plesk with PHP v7.3.25.
I´m trying to install aimeos as a test. I have some troubles with it.
1. After the installation and the import of the page tree v20.10 the layout of the shop is to widht.
2. I get some issues in Typo3 BE
(Core: Error handler (FE): PHP Warning: file_exists(): open_basedir restriction in effect. File(/opt/plesk/php/7.3/share/pear/Less/Cache.php) is not within the allowed path(s): (/var/www/vhosts/ppsmart.at/:/tmp/) in /var/www/vhosts/ppsmart.at/httpdocs/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-core/Bootstrap.php line 80)
You can have a look about the problem with the layout (www.ppsmart.at/shop)
Maybe anyone can help me with it.
Re: Problems with bootstrap package
Post by aimeos » 05 Jan 2021, 08:41
Regarding 2.:
You have to disable open_basedir in your php.ini file because this setting is highly problematic.
