get physcial properties with pin product
GülsümAkça
Post by GülsümAkça » 04 Jan 2021, 11:00
I want to show physical properties like package-weight package-height besides pin products, how can I do this?
thank you
Re: get physcial properties with pin product
Post by aimeos » 05 Jan 2021, 09:01
Add "product/property" to the list of fetched domains in https://aimeos.org/docs/2020.x/config/c ... n/#domains.
Then, you can access the properties using:
$weight = $productItem->getProperties( 'package-weight' )->first()
https://github.com/aimeos/aimeos-core/b ... ce.php#L67
