Create new resource items Postman
CairMK
Post by CairMK » 12 Jan 2021, 10:27
Hi all trying to add a new product using postman, my postman request is:
image 1 auth with laravel passport token
second image json body
what I'm doing wrong pls help
Re: Create new resource items Postman
Post by aimeos » 13 Jan 2021, 09:17
The JSON REST API is only for the frontend and doesn't allow managing products. You need to use the JsonAdm API for managing products:
https://aimeos.org/docs/latest/admin/jsonadm/
CairMK
Post by CairMK » 13 Jan 2021, 09:49
I have changed the URL in postman but still not working no error no info according to the doc how I understand,
the URL is http://localhost:8000/jsonadm/default/product method is post and in the body we need
"data": {
"type": "product",
"attributes": {
"product.code": "test",
"product.label": "Test product",
"product.status": "0"
the token need to be pass in the URL as well or just using postman in the header pls give me an example in postman
Post by aimeos » 13 Jan 2021, 10:40
Don't know Postman but CURL should be similar. Here's the excerpt from the docs:
curl -b cookies.txt -c cookies.txt \
-X POST 'http://localhost:8000/jsonadm/default/product?_token=...' \
-H 'Content-Type: application/json' \
-d '{"data": {
    "type": "product",
    "attributes": {
Make sure you are logged in with an admin account and you pass the Laravel session cookie along with the request.
