500 Error
Shopmister
500 Error
Post by Shopmister » 15 Jan 2021, 11:18
Hey, i have at different things the same error. In the Distribution and the manual
Manual: 20.10.5
Distribution: 20.10.1
Typo3 10.4.12; an symlinkinstallation
PHP Version 7.3.19-1~deb10u1
Database (Default) MySQL 5.5.5-10.3.27-MariaDB-0+deb10u1
Operating System Linux 4.19.0-9-amd64
- The Error cames, if i do the action from aimeos in Extensionmodul, to update the database
- In the Aimeos backend-modul
and sometimes during the installation of the extension
Its a aimeosproblem, all other things works normal, and the frontend with aimeos normal too.
Informations:
in cache di/DependencyInjectionContainer_e5867b4274c5a525322403decadd121fb0382c91
these two things(another ext had some problems with caching path, only a try):
return $this->services['backend.routes_decorated_34'] = $a->extendService('ground', 'backend.routes', $this, $a->extendService('aimeos', 'backend.routes', $this, $a->extendService('static_info_tables', 'backend.routes', $this, $a->extendService('pdfviewhelpers', 'backend.routes', $this, $a->extendService('viewpage', 'backend.routes', $this, $a->extendService('tstemplate', 'backend.routes', $this, $a->extendService('t3editor', 'backend.routes', $this, $a->extendService('sys_note', 'backend.routes', $this, $a->extendService('seo', 'backend.routes', $this, \TYPO3\CMS\Lowlevel\ServiceProvider::configureBackendRoutes($this, $a->extendService('info', 'backend.routes', $this, $a->extendService('felogin', 'backend.routes', $this, $a->extendService('extensionmanager', 'backend.routes', $this, \TYPO3\CMS\Dashboard\ServiceProvider::configureBackendRoutes($this, $a->extendService('beuser', 'backend.routes', $this, $a->extendService('belog', 'backend.routes', $this, $a->extendService('adminpanel', 'backend.routes', $this, $a->extendService('about', 'backend.routes', $this, $a->extendService('rte_ckeditor', 'backend.routes', $this, $a->extendService('setup', 'backend.routes', $this, \TYPO3\CMS\Backend\ServiceProvider::configureBackendRoutes($this, $a->extendService('recordlist', 'backend.routes', $this, $a->extendService('redirects', 'backend.routes', $this, $a->extendService('reports', 'backend.routes', $this, \TYPO3\CMS\Install\ServiceProvider::configureBackendRoutes($this, $a->extendService('form', 'backend.routes', $this, $a->extendService('impexp', 'backend.routes', $this, $a->extendService('filelist', 'backend.routes', $this, $a->extendService('fluid_styled_content', 'backend.routes', $this, \TYPO3\CMS\Frontend\ServiceProvider::configureBackendRoutes($this, $a->extendService('fluid', 'backend.routes', $this, \TYPO3\CMS\Extbase\ServiceProvider::configureBackendRoutes($this, $a->extendService('scheduler', 'backend.routes', $this, \TYPO3\CMS\Core\ServiceProvider::configureBackendRoutes($this, \TYPO3\CMS\Backend\ServiceProvider::getBackendRoutes($this)))))))))))))))))))))))))))))))))));
return $this->services['middlewares_decorated_33'] = $a->extendService('ground', 'middlewares', $this, $a->extendService('aimeos', 'middlewares', $this, $a->extendService('static_info_tables', 'middlewares', $this, $a->extendService('pdfviewhelpers', 'middlewares', $this, $a->extendService('viewpage', 'middlewares', $this, $a->extendService('tstemplate', 'middlewares', $this, $a->extendService('t3editor', 'middlewares', $this, $a->extendService('sys_note', 'middlewares', $this, $a->extendService('seo', 'middlewares', $this, \TYPO3\CMS\Lowlevel\ServiceProvider::configureMiddlewares($this, $a->extendService('info', 'middlewares', $this, $a->extendService('felogin', 'middlewares', $this, $a->extendService('extensionmanager', 'middlewares', $this, \TYPO3\CMS\Dashboard\ServiceProvider::configureMiddlewares($this, $a->extendService('beuser', 'middlewares', $this, $a->extendService('belog', 'middlewares', $this, $a->extendService('adminpanel', 'middlewares', $this, $a->extendService('about', 'middlewares', $this, $a->extendService('rte_ckeditor', 'middlewares', $this, $a->extendService('setup', 'middlewares', $this, \TYPO3\CMS\Backend\ServiceProvider::configureMiddlewares($this, $a->extendService('recordlist', 'middlewares', $this, $a->extendService('redirects', 'middlewares', $this, $a->extendService('reports', 'middlewares', $this, $a->extendService('form', 'middlewares', $this, $a->extendService('impexp', 'middlewares', $this, $a->extendService('filelist', 'middlewares', $this, $a->extendService('fluid_styled_content', 'middlewares', $this, \TYPO3\CMS\Frontend\ServiceProvider::configureMiddlewares($this, $a->extendService('fluid', 'middlewares', $this, \TYPO3\CMS\Extbase\ServiceProvider::configureMiddlewares($this, $a->extendService('scheduler', 'middlewares', $this, \TYPO3\CMS\Core\ServiceProvider::configureMiddlewares($this, \TYPO3\CMS\Core\ServiceProvider::getMiddlewares($this))))))))))))))))))))))))))))))))));
ANd the 500 Error:
https://aimeos2021.domain.de/typo3/inde ... dmin&token jquery.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:7784 =74b3acff0dea71bec45f7eaa2a405a183a28a176 500
attr @ jquery.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:7784
access @ jquery.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:3976
attr @ jquery.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:7741
(anonymous) @ ContentContainer.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:13
mightThrow @ jquery.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:3557
process @ jquery.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:3625
setTimeout (async)
(anonymous) @ jquery.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:3663
fire @ jquery.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:3291
add @ jquery.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:3350
(anonymous) @ jquery.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:3683
Deferred @ jquery.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:3774
then @ jquery.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:3668
setUrl @ ContentContainer.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:13
openInContentFrame @ ModuleMenu.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:13
(anonymous) @ ModuleMenu.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:13
proxy @ jquery.js?bust=65af5649baecf6ad42455ab66643a8e571852ff9:10502
https://aimeos2021.domainname.de/typo3/index.php...
Re: 500 Error
Post by aimeos » 15 Jan 2021, 12:34
Do you have a full PHP stack trace of the error?
Make sure the symlinks for the Aimeos extensions are added correctly if you have a composer based setup:
https://github.com/aimeos/aimeos-typo3#composer
Shopmister
Re: 500 Error
Post by Shopmister » 15 Jan 2021, 13:06
Without composer, only a symlinkistallation
Where i can find the PHP stack trace? I have no idea what that is. i have server access. You mean the logfiles?
By the distributioininstall i have now this error:
PHP Warning: file_exists(): open_basedir restriction in effect. File(/usr/share/php/ScssPhp/ScssPhp/Version.php) is not within the allowed path(s): (/home/users/username/www:/home/users/username/files:/home/users/username/tmp) in /home/users/username/www/Typo3_10/MarketDist_2021/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-core/Bootstrap.php line 80
E_DEPRECATED => 'PHP Runtime Deprecation Notice'
$message = $errorLevels[$errorLevel] . ': ' . $errorMessage . ' in ' . $errorFile . ' line ' . $errorLine;
if ($errorLevel & $this->exceptionalErrors) {
throw new Exception($message, 1476107295);
switch ($errorLevel) {
case E_USER_ERROR:
case E_RECOVERABLE_ERROR:
But for me is the other install more importand
I activated now debug in boths installations, after pushing the database updatescript and in the Aimeos-Modul-area, that errormessage:
Get help in the TYPO3 Wiki
If you need help solving this exception, you can have a look at the TYPO3 Wiki. There you can find solutions provided by the TYPO3 community. Once you have found a solution to the problem, help others by contributing to the wiki page.
Re: 500 Error
Post by aimeos » 17 Jan 2021, 11:10
open_basedir is enabled in you PHP installation and you need to disable it.
Shopmister
Re: 500 Error
Post by Shopmister » 18 Jan 2021, 06:58
Okay, after many forumposts with php knowing people. Its working now!
Thanks, great!
It is possible that functions like Downloadproducts dont work/maybe worked because open dir?
Maybe the other aimeosproblems like the set users to Page 0, only these some things have to do maybe with open_basedir?
Only for information that i can hope this time all will works :)
Ps. But the aimeos Extension, says after Aimeos works again, : PHP setting "open_basedir" is enabled
do Aimeos check only if it somewhere enabled or ist Aimeos checking where exactly? If the first i can ignore that can i?
I did set that for the open_basedir to disable in a form to disable opd on my server:
##DOCROOT##/www:##DOCROOT##/files:##DOCROOT##/tmp:/tmp:/usr/share/php
I set somebody told me only: that the Aimeos can go out of userstorages to usr/share/php
Re: 500 Error
Post by aimeos » 19 Jan 2021, 08:51
These are two different problems. You have to disable open_basedir completely so you won't get into trouble.
The PID 0 for new customers is a missing configuration setting:
plugin.tx_aimeos.settings.mshop.customer.manager.typo3.pid-default = ...
Shopmister
Re: 500 Error
Post by Shopmister » 20 Jan 2021, 09:24
Wich paths need Aimeos outsite of user exactly? I could write all paths in the configuration.
Because i disabled in these files in the phpversion 7.3 open_basedir
- php.ini-production.cli
-php.ini-production
- developement
And aimeos says that open_basedir not disabled
And i restartet the server, to be sure. Same
Where i have to write the configuration. In the setup/config? Like the configurations from the distribution?
I have to set the numer of the pid of the folder then, like 1,9 ....?
like: plugin.tx_aimeos.settings.mshop.customer.manager.typo3.pid-default = 3
I had for few days the problem that i set a setting about the congifield in the templatemodul, and deleted the setting. And the functinality wasnt away. i hope normal settings are easy to handle :).
Exist a list of importand setting, i have to set? Thats most save that things like users cant login because all users are on page "0", not happening if its ,livewebsite.
Re: 500 Error
Post by aimeos » 21 Jan 2021, 09:35
Shopmister wrote: 20 Jan 2021, 09:24 And aimeos says that open_basedir not disabled
If Aimeos is still complaining, it's still active in your PHP setup.
Yes, add that to the setup TypoScript template of your root page.
Shopmister wrote: 20 Jan 2021, 09:24 I had for few days the problem that i set a setting about the congifield in the templatemodul, and deleted the setting. And the functinality wasnt away. i hope normal settings are easy to handle :).
The "constants" TypoScript contains the most important, predefined settings.
