Categories list don't show in the Admin
Hi there,
I have a situation that has stumped me for last 2 days. Here is my setup.
Aimeos for Laravel : ^2020.07
Laravel: ^7.24
PHP: ^7.2.5
MySQL: 5.7
Server: IIS 8 on Windows Sever 2016 My composer.json screenshot is attached.
I developed the website on my dev machine. It worked perfect. Now I need to move it to staging server. I copy over the Database and the PHP code, run composer update, run php artisan aimeos:setup and I have my website up and running on the staging server. See attached files and When going in admin panel on staging, the catalog page is empty. It does not load the tree of categories. On product edit page, on categories tab, the categories do not load in the dropdown either. I am pulling my hair out as I reach my wits end here.
I have repeated the process of uploading the website multiple times with same results. I even setup an empty fresh laravel setup and just added aimeos without any customization with demo data but the problem is same.
I have narrowed down the issue to the absence of ajax calls on categories page that load the catalog tree. On my dev machine I have 3 ajax calls when categories page is loading in admin panel But these ajax calls do not happen on the staging server. The code responsible for this call is in \ai-admin-jqadm\admin\jqadm\themes\catalog.js the function Aimeos.options.done() does not get called on the staging server. I have tried to figure out where it is being called from in the code but I want not successful. I need immediate assistance. The client is waiting for the demo since and I have already postponed things twice as I am unable to set things up on the staging server.
Your able guidance is highly appreciated. Thank you.
Laravel: ^7.24
PHP: ^7.2.5
MySQL: 5.7
Re: Categories list don't show in the Admin
Adding more screenshots to support my point.
- no_ajax_call_on_staging.png (13.9 KiB) Viewed 4834 times
- catalog_js_file.png (79.85 KiB) Viewed 4834 times
- ajax_calls_work_fine_on_dev.png (29.83 KiB) Viewed 4834 times
Hello. I'm awaiting some input to resolve this matter. the situation is sort of urgent for me. Thank you for understanding.
Your problem is probably not the code but your web server and I guess it doesn't allow HTTP OPTIONS requests. Check that in the browser console if there are any errors when working on your staging server.
Thank you very much for the pointer. It really helped me solve the problem.
For future, if anyone finds this thread, this https://stackoverflow.com/questions/224 ... ns-request helped me set things up on IIS. In short, you need to allow OPTIONS calls on the IIS server which are by default not set.
