run Test Command in Aimeos
is that possible when I test OmniPayTest.php I receive 25 errors !
why it doesn't recognize TestHelper even it run the bootstrap.php that belongs to ext/ai-payment !
I run the test like that :
./vendor/bin/phpunit --configuration ext/ai-payments/lib/custom/tests/phpunit.xml ext/ai-payments/lib/custom/tests/MShop/Service/Provider/Payment/OmniPayTest.php
neither : php artisan aimeos:setup unittest unittest
allows me to specified which Test class I need to run !
any help ?
any help ?
Re: run Test Command in Aimeos
You forgot the "--bootstrap vendor/autoload.php" part:
./vendor/bin/phpunit --bootstrap=vendor/autoload.php -c
ext/ai-payments/lib/custom/tests/phpunit.xmlProfessional support and custom implementation are available at Aimeos.com
thanks for reply ..
it still give me that 86 errors as it didn't recognized autoload
I tried it : $ ./vendor/bin/phpunit --bootstrap=vendor/autoload.php -c ext/ai-payments/lib/custom/tests/phpunit.xmlaimeos wrote: 17 Jan 2021, 17:18 You forgot the "--bootstrap vendor/autoload.php" part:Code: Select all
Here's the documentation how to setup the environment for testing so it works without problems:
https://aimeos.org/docs/latest/develope ... sion-tests
Make sure, you add the packages required by the extensions to your root composer.json file and run "composer up" afterwards.
