Suggested Product selection in Product Detail
GagDalakyan
Post by GagDalakyan » 18 Jan 2021, 08:01
Laravel : 6.20.5
Aimeos : 2020.10
PHP Version : 7.2
Environment : Windows
Hello.
Aimeos is awesome.Thanks
Suggested products in Product detail page don`t show selection product variant products.
In ListRefItems for suggested product absent product domain. How can i add this.
Sorry for bad English )
Re: Suggested Product selection in Product Detail
Post by aimeos » 19 Jan 2021, 10:51
It will be shown if you add this:
'basket-add' => true
in your catalog/detail body template: https://github.com/aimeos/ai-client-htm ... d.php#L503
The accepted options of the partial are documented here:
https://github.com/aimeos/ai-client-htm ... php#L8-L14
GagDalakyan
Post by GagDalakyan » 19 Jan 2021, 11:25
Thanks for your reply.
But it still don`t work. It gives an empty map
$productItem->getRefItems( 'product', 'default', 'default' );
Post by aimeos » 20 Jan 2021, 11:49
Also add this setting to retrieve one more product level:
mshop/common/manager/maxdepth => 3
https://aimeos.org/docs/2020.x/config/m ... /#maxdepth
You have to adapt the styling because the standard Aimeos CSS doesn't add styles for that.
GagDalakyan
Post by GagDalakyan » 20 Jan 2021, 14:10
Many thanks. It works
