Class '\Omnipay\quickpay\Gateway' not found
mahrez
Post by mahrez » 20 Jan 2021, 16:29
I downloaded Omnipay driver for the Quickpay payment processor from GitHub : https://github.com/thomasbnielsen/omnipay-quickpay
Copied contents to typo3conf/ext/aimeos_pay/Resources/Libraries/omnipay/quickpay
Added service in Aimeos : Screenshot https://i.ibb.co/T25WzP4/image.png
When checkout in webshop, I only get:
I'm using Aimeos ext and aimeos_pay v19.10.1 and TYPO3 v9.5.14
Also, I executed : COMPOSER=composer.json composer update --no-dev on the : /typo3conf/ext/aimeos but I get this error : https://i.ibb.co/bzSjsWq/image.png
Re: Class '\Omnipay\quickpay\Gateway' not found
Post by aimeos » 21 Jan 2021, 17:01
aimeos_pay is no longer supported because it's impossible to offer that extension for TYPO3 v9+ due to duplicate classes.
The only way is installing TYPO3 and Aimeos via composer and then execute:
composer req ai-payments nobrainerweb/omnipay-quickpay
to install Omnipay and the Quickpay driver too.
mahrez
Post by mahrez » 04 Feb 2021, 20:30
Thank you for reply.
Please, What do I do if it's not a new TYPO3 installation and it's not installed with comopser?
Post by aimeos » 05 Feb 2021, 08:31
- Install a new setup with composer including the extensions you have in your old installation
- Copy the typo3conf/LocalConfiguration.php from your old installation to the new one
- Move the existing directory to a backup location
- Move the new application to one directory below the document root and change the htdocs directory to the public directory in your web server
Keep care about the last point! Composer based installations have a different directory layout (docroot is now the public subdirectory).
mahrez
Post by mahrez » 28 Feb 2021, 12:02
I reinstalled the site and aimeos using composer and I added :
"league/omnipay": "^3",
"nobrainerweb/omnipay-quickpay": "^3.0"
Everything is functional except the callbackurl ... we get
HTTP Status code: 500
After some diagnosis I found this error :
Call to undefined method Omnipay\Quickpay\Message\Notification::send()
in /var/www/example.com/public/typo3conf/ext/aimeos/Resources/Private/Extensions/ai-payments/lib/custom/src/MShop/Service/Provider/Payment/OmniPay.php line 504
Post by aimeos » 02 Mar 2021, 09:54
Seems like the Omnipay driver is incomplete and the send() method of the reponse object isn't implemented.
