Can't install Aimeos on TYPO3 V10.4.12 with composer v2
gizmo
Post by gizmo » 30 Jan 2021, 15:03
I'm trying to install the Aimeos EXT on a TYPO3 v10.4.12 installation via composer.
The composer is version 2.0.8 and is using PHP 7.4.13. Its running on a Apache Linux Server.
When I require the aimeos package (composer req aimeos/aimeos-typo3) I get the following error:
Problem 1
- aimeos/aimeos-typo3[20.10.2, ..., 20.10.5] require aimeos/ai-gettext 2020.10.* -> satisfiable by aimeos/ai-gettext[2020.10.1, 2020.10.2].
- aimeos/ai-gettext[2020.10.1, ..., 2020.10.2] require composer/installers ^1.0 -> satisfiable by composer/installers[v1.0.0, ..., v1.10.0].
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.10.0.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.9.0.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.21.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.20.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.19.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.18.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.17.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.16.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.15.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.14.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.13.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.12.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.11.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.10.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.9.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.8.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.7.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.6.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.5.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.4.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.3.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.2.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.1.
- typo3/cms-composer-installers v3.0.1 conflicts with composer/installers v1.0.0.
- aimeos/aimeos-typo3 20.10.1 requires composer/installers 1.0.24 -> satisfiable by composer/installers[v1.0.24].
- typo3/cms-core v10.4.12 requires typo3/cms-composer-installers ^2.0 || ^3.0 -> satisfiable by typo3/cms-composer-installers[v3.0.1].
- composer/installers v1.0.22 requires composer-plugin-api 1.0.0 -> found composer-plugin-api[2.0.0] but it does not match the constraint.
- composer/installers[v1.0.23, ..., v1.8.0] require composer-plugin-api ^1.0 -> found composer-plugin-api[2.0.0] but it does not match the constraint.
- typo3/cms-core is locked to version v10.4.12 and an update of this package was not requested.
- Root composer.json requires aimeos/aimeos-typo3 ^20.10 -> satisfiable by aimeos/aimeos-typo3[20.10.1, ..., 20.10.5].
You are using Composer 2, which some of your plugins seem to be incompatible with. Make sure you update your plugins or report a plugin-issue to ask them to support Composer 2.
Is the newest Version of Aimeos (20.10.5) not compatible with composer version 2?
Re: Can't install Aimeos on TYPO3 V10.4.12 with composer v2
Post by aimeos » 01 Feb 2021, 08:40
It is but TYPO3 limits composer/installers package to 1.0.24 which isn't compatible to composer 2.
The problem is described here: https://github.com/composer/installers/issues/470
gizmo
Post by gizmo » 04 Feb 2021, 17:42
Thanks for the replay. I've read the Github Issue. If i want to install Aimeos right now, I have to downgrade to composer to v1?
gizmo
Post by gizmo » 06 Feb 2021, 11:03
In the Github Issue (https://github.com/composer/installers/issues/470) it was mentioned, that currently you are only able to install Aimeos if you disable the installer via the root composer.json.
For example:
 "extra": {
      "installer-disable": true
But I wasnt able to disable the installer. I'm assuming I have to disable the TYPO3 installer since this is the one that requires composer v1.
I've also tried the following:
 "extra": {
      "installer-disable": "typo3-cms-extension"
Unfortunatelly I wasn't able to install the Aimeos EXT with these settings. Was anyone successfull in installing Aimeos since the composer V2 Update?
Post by aimeos » 06 Feb 2021, 16:37
No, only composer v1 is working at the moment.
Post by aimeos » 23 Mar 2021, 12:50
You have missed adding the "scripts" to your composer.json file:
https://github.com/aimeos/aimeos-typo3#composer
