override translations for Login Box
S0l
Post by S0l » 02 Feb 2021, 15:02
we have our default (= es) Login box show up like this:
Login
Username [...........]
Password [...........][
[Login]
but we want to adapt to our "default" language, which is "es" so it looks like
Iniciar Sesión
Usuario [...........]
Contraseña [...........][
[Login]
we tried to override with e.g.
plugin.tx_felogin_pi1._LOCAL_LANG.default {
    username =Usuario
    password = Contraseña
but this does not work.
We have successfully adapted some of the necessary- texts regarding the LOGIN process/account page have su been changed in our es_CL.po file residing under
typo3conf/ext/aimeos/Resources/Private/Extensions/ai-client-html/client/i18n
but things like the "Forgot Password" Page and Emails sent to the customer still appear only in English or in a mixture of English and Spanish ( Confirmation Page of Lost Password Sent Email). Those msgids dont show up in the core-client.pot nor core-client-code.pot files...
Is there a way to override those default (en) texts so it appears in Spanish uniformly?
Do you have any ideas?
aimeos 20.10.4 with aimeos_dist 20.10.1 on Typo3 10.4.12 with php 7.3.19-1 ~ deb10u1
Re: override translations for Login Box
Post by aimeos » 05 Feb 2021, 06:53
The login is provided by another TYPO3 plugin (not by Aimeos) so you have to look whre you have to add the translations there (typically in a locallang.xml file).
S0l
Post by S0l » 09 Feb 2021, 21:06
Yes, thank you, this was the right idea. There where no language translation files for my language (es) for the felogin, so I copied existing German files over to a newly made Spanish directory branch:
 cp ./typo3conf/l10n/de/felogin/Resources/Private/Language/de.locallang.xlf typo3conf/l10n/es/felogin/Resources/Private/Language/es.locallang.xlf
 cp ./typo3conf/l10n/de/felogin/Resources/Private/Language/de.Database.xlf typo3conf/l10n/es/felogin/Resources/Private/Language/es.Database.xlf
Just needed to change the German texts to Spanish texts, using the English source strings as a base. It is surely not the best way of doing it, but it works for now...
