property in filter
GülsümAkça
property in filter
Post by GülsümAkça » 11 Feb 2021, 11:11
Can I show the properties of the product in filter? eg products under or over 5 kg.
thank you:)
Re: property in filter
Post by aimeos » 12 Feb 2021, 08:18
Not by default and you would have to extend the catalog/filter template and the client/html class to filter for those values.
GülsümAkça
Post by GülsümAkça » 13 Feb 2021, 14:15
How can I get the max value of the property in addData() function
Post by aimeos » 15 Feb 2021, 10:42
Only by iterating over all products and that's not advisable so you should use some fixed categories like
- below 5 kg
- 5 to 10 kg
- above 10 kg
