Change search functionality and override files in vendor
GagDalakyan
Post by GagDalakyan » 01 Mar 2021, 11:37
Hi. Thanks for your great package and support.
I want to change search functionality, as you described in post13756.html#p13756 to search products by category name.
I want to know may i override
aimeos-core/lib/mshoplib/config/mshop/index.php,
aimeos-core/lib/mshoplib/src/MShop/Index/Manager/Text/Standard.php
files or i shall edit it in vendor folder.
Thanks.
Re: Change search functionality and override files in vendor
Post by aimeos » 01 Mar 2021, 11:43
Always extend the orginal classes in your own extension, never overwrite core files! Otherwise, your changes would be lost if you run "composer update".
GagDalakyan
Post by GagDalakyan » 01 Mar 2021, 11:50
Ok. But how i must override for example "aimeos-core/lib/mshoplib/config/mshop/index.php" this file?
If i create index.php file in config, it don`t work.
Post by aimeos » 03 Mar 2021, 09:14
The directory structure within the ./config folder of your extension is also important. To overwrite the "domains" setting add a folder named "mshop" and then add the index.php file within.
The easier way is to add it to the ./config/shop.php file of your Laravel application:
'mshop' => [
	'index' => [
		'manager' => [
			'standard' => [
				'domains' => [
					'catalog' => ['text'],
					'attribute' => 'attribute',
					'product' => ['default'],
					'price' => ['default'],
					'text' => 'text',
