i would like to add a column and need to write some query by myself.. Need a help
kishore
Post by kishore » 04 Mar 2021, 10:07
Hello buddies I am Laravel developer and I would like to alter existing table and like to change the query... it's hard to find the db flow here..
help me to understand how you are connecting to SQL queries.
It's my new organization and being with this task for 2 days so, any help would be nice ASAP... thanks in advance.
kishore
Re: i would like to add a column and need to write some query by myself.. Need a help
Post by kishore » 05 Mar 2021, 12:10
Hello Admin ?????
you replied everyone questions without mine.
Can you please reply.... is it possible or not..
so, i can tell my organization that lets check for other packages
Post by aimeos » 05 Mar 2021, 14:23
First of all, Aimeos is an Open Source project mainly supported by developers using it for their own projects so we are all helping others in our spare time and it depends on how much work we have to do on our own. If you need immediate support, you should pay the Aimeos company for 1:1 developer support: https://aimeos.com/support
Next, your question is very unspecific so I can only give you general answers.
To extend a table read about migrations first:
https://aimeos.org/docs/latest/infrastr ... igrations/
To fetch and save additional properties, read about extending managers:
https://aimeos.org/docs/latest/infrastr ... -managers/
kishore
Post by kishore » 08 Mar 2021, 05:48
Thanks for your responding and reply.... :D
