HTML tags visible in the front-end - SUPPLIERS
ivanp
Post by ivanp » 05 Mar 2021, 17:58
In my first test with Aimeos (TYPO3 10.4.14 + aimeos_dist 20.10.1 / PHP 7.3 / utf8_unicode_ci / Linux) I notice that the HTML-tags keep appearing in the front-end adding:
Add: Suppliers -> Text -> Type (Name and/or Long-/Short descriptions).
Front-end output example: This text<strong> <em>shows</em> </strong>HTML tags!!!!
Anyone else having this same problem or a solution?
Re: HTML tags visible in the front-end - SUPPLIERS
Post by aimeos » 08 Mar 2021, 09:16
Where in the frontend do they appear? In the catalog/detail component?
ivanp
Post by ivanp » 08 Mar 2021, 10:05
aimeos wrote: 08 Mar 2021, 09:16 Where in the frontend do they appear? In the catalog/detail component?
They are visible in the "Supplier information" part.
Post by aimeos » 09 Mar 2021, 08:29
Now, HTML tags in texts are not encoded any more in the supplier section:
https://github.com/aimeos/ai-client-htm ... b22409360c
