How to get attribute's option on frontend
Could you give me an idea how can I get an attribute's option (see screenshot) on frontend?
I'd like to get the "colorcode" option for each color product attribute on frontend.
In user manual there is
"Option/Value (optional)
Arbitrary list of key/value pairs that will be available with each image/media item in the frontend"
But how?
But how?
- Screenshot_39.jpg (43.35 KiB) Viewed 6191 times
Re: How to get attribute's option on frontend
For example, you can get the value here:
https://github.com/aimeos/ai-client-htm ... d.php#L375
using:
If you use a media property instead, you can also use it in the partial rendering the icons:
https://github.com/aimeos/ai-client-htm ... hp#L52-L57
by using:
using:
$listItem->getConfigValue( 'colorcode' )https://github.com/aimeos/ai-client-htm ... hp#L52-L57
by using:
$item->getProperties( 'colorcode' )->first()Professional support and custom implementation are available at Aimeos.com
I'm wondering if the OP resolved the issue. I'm dealing with the same trouble, where catalog item has an image. while i'm setting options to the image i'm not able to retrieve that option.
Aimeos\MShop\Media\Item\Standard {#2132 ▼
-langid: "en"
-prefix: "media."
-available: true
-modified: false
#bdata: array:14 [▶]
-listItems: []
-listRefItems: []
-listRmItems: []
-listPrepared: true
-listRmMap: []
-listMap: []
-listMax: 0
-propItems: []
-propRmItems: []
-propMax: 0
$image->getProperties('imageopt') returns an empty map, despite the option is set for the media
-langid: "en"
-prefix: "media."
-available: true
-modified: false
-listItems: []
-listRefItems: []
-listRmItems: []
-listPrepared: true
-listRmMap: []
-listMap: []
-listMax: 0
-propItems: []
-propRmItems: []
-propMax: 0
The option/value pairs are not stored as properties but in "bdata[media.config]" of the item instead. You can get the value using:
$mediaItem->getConfigValue( 'colorcode' );Professional support and custom implementation are available at Aimeos.com
