change direction-right to left
khizar
Post by khizar » 09 Mar 2021, 11:51
Hey aimeos.
Is there any option to move the direction from right to left when language is changed for example if arabic language is selected i want the direction from right to left, i mean side bar move to the right side of screen.Please note that i have added translations now i just want to change the direction
Re: change direction-right to left
Post by aimeos » 09 Mar 2021, 18:05
The new Aimeos admin backend is optimized for RTL languages:
The Aimeos versions 2020.10 and before use Bootstrap 4 which doesn't support RTL languages well. You can try to add the CSS rule
direction: rtl
to the root HTML element but that will only do half of the job.
khizar
Post by khizar » 12 Mar 2021, 07:16
aimeos wrote: 09 Mar 2021, 18:05 The new Aimeos admin backend is optimized for RTL languages:
direction: rtl
can you please guide me how can i update aimeos.I am using laravel 8.
If i update aimeos will i be able to use that functionality.
Note : i ran composer update command and it gave an error
Script @php artisan migrate handling the post-update-cmd event returned with error code 1
khizar
Post by khizar » 12 Mar 2021, 11:55
waiting for reply
khizar
Post by khizar » 13 Mar 2021, 05:32
waitng for reply
Post by aimeos » 13 Mar 2021, 16:05
If you use composer 2.x, executing
composer req aimeos/aimeos-laravel:dev-master
php artisan aimeos:setup
should do the job. Note, that you will upgrade to a new major version (2020.10 -> 2021.x) which includes breaking changes that may not be backward compatible to the code you've written to extend Aimeos up to now. Here are the most important changes but they are not complete yet:
https://github.com/aimeos/aimeos-docs/b ... /2021.x.md
AhmadHelali
Post by AhmadHelali » 06 Mar 2023, 16:29
direction: rtl
But the Client interface does not change the direction to RTL (the front not the admin)
