Custom domain for each sites
AmzoooJibal
Post by AmzoooJibal » 12 Mar 2021, 20:19
i have installed aimeos in xampp in local machine, then I have created a site with this commande: php artisan aimeos:setup seller1.com
i have configured my host and vhots like this:
host:
127.0.0.1       www.seller1.com
vhost:
<Directory "D:/aimeos/myshop/public">
        Options Indexes FollowSymLinks MultiViews
        AllowOverride all
        Order Deny,Allow
        Allow from all
        Require all granted
</Directory>
<VirtualHost *:80>
    DocumentRoot D:/aimeos/myshop/public
    ServerName www.seller1.com
</VirtualHost>
but when I access to the url:www.seller1.com i have the default marketplace not the seller1
any help please ?
AmzoooJibal
Re: Custom domain for each sites
Post by AmzoooJibal » 13 Mar 2021, 12:33
my conf/shop.php is like this:
<?php
$routes = [];
if( config( 'app.shop_multishop' ) || config( 'app.shop_registration' ) ) {
	$routes = ['routes' => [
		'admin' => ['prefix' => 'admin', 'middleware' => ['web', 'verified']],
		'jqadm' => ['prefix' => 'admin/{site}/jqadm', 'middleware' => ['web', 'auth', 'verified']],
		'jsonadm' => ['prefix' => 'admin/{site}/jsonadm', 'middleware' => ['web', 'auth', 'verified']],
		'jsonapi' => ['prefix' => 'jsonapi/{site}', 'middleware' => ['web', 'api']],
		'account' => ['prefix' => 'profile/{site}', 'middleware' => ['web', 'auth']],
		'default' => ['prefix' => 'shop/{site}', 'middleware' => ['web']],
		'update' => ['prefix' => '{site}'],
return $routes + [
	'apc_enabled' => false, // enable for maximum performance if APCu is availalbe
	'apc_prefix' => 'aimeos:', // prefix for caching config and translation in APCu
	'pcntl_max' => 4, // maximum number of parallel command line processes when starting jobs
        'routes' => [
            'admin' => ['domain' => '{site}', 'prefix' => 'admin', 'middleware' => ['web']],
            'jqadm' => ['domain' => '{site}', 'prefix' => 'admin/jqadm', 'middleware' => ['web', 'auth']],
            'jsonadm' => ['domain' => '{site}', 'prefix' => 'admin/jsonadm', 'middleware' => ['web', 'auth']],
            'jsonapi' => ['domain' => '{site}', 'prefix' => 'jsonapi', 'middleware' => ['web', 'api']],
            'account' => ['domain' => '{site}', 'prefix' => 'profile', 'middleware' => ['web', 'auth']],
            'default' => ['domain' => '{site}', 'prefix' => 'shop', 'middleware' => ['web']],
            'update' => ['domain' => '{site}'],
Post by aimeos » 13 Mar 2021, 16:07
First, "www.seller1.com" is not the same as "seller1.com"!
To configure custom domain routing read:
https://aimeos.org/docs/latest/laravel/ ... he-routing
AmzoooJibal
Post by AmzoooJibal » 13 Mar 2021, 18:16
i hve read this link many times and i have added this to my config/shop.php :
<?php
$routes = [];
if (config('app.shop_multishop') || config('app.shop_registration')) {
    $routes = [
        'routes' => [
return $routes + [
        'routes' => [
            // Docs: https://aimeos.org/docs/Laravel/Custom_routes
            // Multi-sites: https://aimeos.org/docs/Laravel/Configure_multiple_shops
and also activate multistore:
SHOP_MULTISHOP=true
SHOP_REGISTRATION=true
and i have just installed new version and test all this domains:
php artisan aimeos:setup http://www.seller1.com
php artisan aimeos:setup www.seller1.com
but allways i have the default store with demo article, my question where is the www.seller1.com store ? why when i access www.seller1.com the default store is shown ?
Thanks for your help
AmzoooJibal
Post by AmzoooJibal » 13 Mar 2021, 21:15
ok i found the problem, it's not verry calire in documentaion so i have changed:
to 'default' => ['domain' => '{site}', 'prefix' => '', 'middleware' => ['web']],
and now its working
Post by aimeos » 14 Mar 2021, 14:59
If you enable one or both of these settings
SHOP_MULTISHOP=true
you also need to change the route config in the if-block, not in the block that's part of the return statement.
deepstyle
Post by deepstyle » 05 May 2021, 04:48
AmzoooJibal wrote: 13 Mar 2021, 12:33 my conf/shop.php is like this:
<?php
$routes = [];
return $routes + [
        'routes' => [
deepstyle
Post by deepstyle » 05 May 2021, 04:49
Hi
I have installed amieos but I am not able to do this multitenant settings can you help Mr I am ready to pay you
Post by aimeos » 05 May 2021, 05:20
If you need paid support, the Aimeos company offers it:
https://aimeos.com/support
