Voucher for the first order
traiyani75
Post by traiyani75 » 13 Mar 2021, 19:16
We are using JSON APIs into mobile application. We also used different types of vouchers as well.
We want to create voucher which user can use for the first order only. So, is there any way to prepare such type for the voucher ?
Looking for your reply
Thanks in advance. :)
Re: Voucher for the first order
Post by aimeos » 14 Mar 2021, 15:11
Yes, you have to implement a coupon decorator similar to this one:
https://github.com/aimeos/aimeos-core/b ... r/Once.php
Just copy, paste and rename the code and remove the conditions in $expr you don't want.
