Override aimeos-laravel views ?
AmzoooJibal
Post by AmzoooJibal » 15 Mar 2021, 19:26
ther is any way to override the aimeos-laravel views in custom generate extension ? if yes in wich file ? because i have place the views jqadm/index.blade.php in each folder of my extension but not overriding the existing one ?
Thank you
Re: Override aimeos-laravel views ?
Post by aimeos » 16 Mar 2021, 08:44
AmzoooJibal
Post by AmzoooJibal » 16 Mar 2021, 16:00
ok greate thank you
