How to get laravel version 8 from aimeos full application.
Abhiraj
Post by Abhiraj » 24 Mar 2021, 15:28
I went through the guideline to install the aimeos as a new fresh application to test and learn.
https://github.com/aimeos/aimeos
The composer command to install this package installs lararvel 6. I tried to change composer.json for laravel 8, but then as suspected other dependencies error start coming. So how to get new fresh aimeos application with laravel v8.
Re: How to get laravel version 8 from aimeos full application.
Post by aimeos » 26 Mar 2021, 06:31
Install a new Laravel 8 application first and then install Aimeos as described in the aimeos/aimeos-laravel repository:
https://github.com/aimeos/aimeos-larave ... pplication
Note: The Aimeos distribution uses Laravel LTS (long term support) versions only, so currently we use Laravel 6 LTS and we will switch to Laravel 9 LTS which will be released in September.
