Upload media and attach to product from custom form
GagDalakyan
Post by GagDalakyan » 26 Mar 2021, 14:49
Good day !
I have created custom pages for specific users. They can create products with attributes, prices, categories from that page. I used aimeos managers, everything works fine.
But i have an issue with media upload. This is my code.
$mediaFile = $request->file('main-image');
$mediaManager = \Aimeos\MShop::create( $context, 'media' );
$mediaItem = $mediaManager->createItem();
$mediaItem->setDomain('product');
$mediaItem->setUrl($mediaFile);
$mediaItem->setPreview($mediaFile);
$mediaItem->setStatus('1');
$mediaItem->setType('default');
$mediaItem->setMimeType($mediaFile->getMimeType());
$mediaManager->saveItem($mediaItem, true);
How can i create previews, with sizes 240, 720, 800px, such as aimeos medias in database.
And generate media link same as aimeos do this.
Many thanks!
Re: Upload media and attach to product from custom form
Post by aimeos » 28 Mar 2021, 08:04
Use the media controller for that:
https://github.com/aimeos/aimeos-core/b ... /Iface.php
Here you can see how it's used by the Aimeos admin backend:
https://github.com/aimeos/ai-admin-jqad ... #L380-L384
GagDalakyan
Post by GagDalakyan » 28 Mar 2021, 15:36
Many thanks for your reply !
I shall try it.
Now i have another problem.
I want to get products which have stock greater than zero.
This is my code.
$products = \Aimeos\Controller\Frontend::create( $context, 'product' )
		->sort( $sort )
		->category( $catids, 'default', $level )
		->allOf( $view->param( 'f_attrid', [] ) )
		->text( $view->param( 'f_search' ) )
		->uses( $domains );
		if( (isset($_GET['f_stock']) && $_GET['f_stock'] == '1')) {
			$products = $products->isInStock();
		$products = $products->search( $total );
And this is isInStock method.
	public function isInStock() : Iface
		$hasfcn = $this->filter->createFunction( 'product:has', ['stock'] );
		$this->conditions['is-on-sale'] = $this->filter->compare( '>=', $hasfcn, '1' );
		return $this;
I tried everything )) Please help me if it is possible to do.
Post by aimeos » 31 Mar 2021, 12:39
There's no easy way to filter products by stock because there's no direct relation. Stock levels are loaded in by an async AJAX call because they are highly volatile. There have been discussed strategies using an "in-stock" attribute but you would have to implement the whole handling yourself.
GagDalakyan
Post by GagDalakyan » 01 Apr 2021, 08:16
I did it :)) May be someone else need this. Here is example
This is product builder
	$func = $this->filter->createFunction( 'product:stock', [$this->getContext()->getLocale()->getCurrencyId()] );
	$this->conditions['is-in-stock'] = $this->filter->compare( '>', $func, 0 );
	return $this;
'product:stock' => array(
	'code' => 'product:stock()',
	'internalcode' => 'msto."stocklevel"',
	'internaldeps' => ['INNER JOIN "mshop_stock" AS msto ON ( msto."productcode" = mpro."code" )'],
	'label' => 'Product stock, parameter(<currency ID>)',
	'type' => 'integer',
	'internaltype' => \Aimeos\MW\DB\Statement\Base::PARAM_INT,
	'public' => true,
Post by aimeos » 02 Apr 2021, 17:03
Be aware that joining the stock table for products is painfully slow if you have more than a few hundered products!
