Edit Products
khizar
Edit Products
Post by khizar » 29 Mar 2021, 09:43
Hi aimeos,
I have integrated aimeos with laravel.
Versions:
"laravel/framework": "^8.12",
"aimeos/aimeos-laravel": "~2020.10"
My problem is that when i edit my products click on save button it gives error(i.e select type)
now when i select type as default
both(Media and Prices) and save product, it successfully updates but when i again try to edit that product the type select box is not preselected as default and i have to set type as default for all the select boxes again and save product.
please guide me what should i do that when i edit product, type select box should be pre selected with value which i selected during editing time.
Re: Edit Products
Post by aimeos » 31 Mar 2021, 16:56
A standard Aimeos setup doesn't show that behavior and there, the labels are named "Standard" not "default". Can you post a screenshot of your mshop_media_type and mshop_product_list_type tables?
