Add product to basket
marlonsamot
Post by marlonsamot » 13 Apr 2021, 12:32
Hi devs, please help me with this. Please help how to add product in basket in controller. Newbie here thanks!
Re: Add product to basket
Post by aimeos » 15 Apr 2021, 06:41
The controllers are available here:
https://github.com/aimeos/ai-controller ... r/Frontend
For the basket controller, have a look at the interface for the available methods:
https://github.com/aimeos/ai-controller ... /Iface.php
To add a product to the basket, use:
$product = \Aimeos\Controller\Frontend::create( $context, 'product' )->find( 'myprodcode', ['text', 'price', 'media', 'attribute'] );
\Aimeos\Controller\Frontend::create( $context, 'basket' )->addProduct( $product, );
How you get the context object depends on your host application. For Laravel, please read:
https://aimeos.org/docs/latest/laravel/ ... end-aimeos
marlonsamot
Post by marlonsamot » 19 Apr 2021, 12:32
What would be the value of context ? i'm just using function from controller. Other programmer just pass me a product id that would be a key to add a basket.
For example, $product_id = 15
What would be the right code to add to basket.
Post by aimeos » 20 Apr 2021, 10:44
For IDs, use get() instead of find().
How to get the context depends on your host application. What do you use? Laravel?
marlonsamot
Post by marlonsamot » 20 Apr 2021, 11:43
Yes laravel. I want to add to basket using parameter product id
Post by aimeos » 24 Apr 2021, 08:42
Please read this article how to get the context object:
https://aimeos.org/docs/latest/laravel/ ... os-objects
