json API does not return process link for gateway payment (Stripe)
HADA
Post by HADA » 13 Apr 2021, 15:54
Hi aimeos,
I'm working with aimeos on laravel for a big project, i'm first testing the api to see how we will manage things.
Everything looks fine, but i have a small issue after creating order invoice. The response does not contain process link to proceed the payment or (gateway redirection)
    "meta": {
        "total": 1,
        "prefix": null,
        "content-baseurl": "http://aimeos.localhost",
        "csrf": {
            "name": "_token",
            "value": "PAC8hnfmOfIs8g1v2lTiqXYl52e8RQ6pTPL06OMU"
    "links": {
        "self": "http://aimeos.localhost/jsonapi/order"
    "data": {
        "id": "20",
        "type": "order",
        "links": {
            "self": {
                "href": "http://aimeos.localhost/jsonapi/order?id=20",
                "allow": [
                    "GET"
            "process": {
                "href": "",
                "allow": [
                    "POST"
                "meta": {
                    "paymenttoken": {
                        "code": "paymenttoken",
                        "type": "string",
                        "label": "Authentication token",
                        "public": false,
                        "default": "",
                        "required": true
                    "payment.cardno": {
                        "code": "payment.cardno",
                        "type": "container",
                        "label": "Credit card number",
                        "public": true,
                        "default": "",
                        "required": false
                    "payment.expiry": {
                        "code": "payment.expiry",
                        "label": "Expiry",
                        "public": true,
                        "default": "",
                        "required": false
                    "payment.cvv": {
                        "code": "payment.cvv",
                        "label": "Verification number",
                        "public": true,
                        "default": "",
                        "required": false
        "attributes": {
            "order.id": "20",
            "order.type": "jsonapi",
            "order.statusdelivery": -1,
            "order.statuspayment": -1,
            "order.datepayment": null,
            "order.datedelivery": null,
            "order.relatedid": null
        "relationships": {}
    "included": []
I'm using Stripe by the way, configured and tested from the front interface, and it works fine.
Is there someway i could solve this or it's json api does not manage stripe yet (aimeos 2021.04)
Thank you
Re: json API does not return process link for gateway payment (Stripe)
Post by aimeos » 15 Apr 2021, 06:50
Stripe implements CC handling using their Javascript library, which creates the form, sends the data to their servers and returns a token for the payment. Thus, there's no redirect to the Stripe server at all for the customer.
If you want to build a PWA, you have to add Stripe JS and implement calling the Stripe JS methods in the frontend yourself.
