Use arabic language with latin numbers
mahmoud
Post by mahmoud » 18 Apr 2021, 14:12
windows 10: 64
PostgreSQL 9.6.15
Laravel Framework 8.37.0
PHP 7.4.16
"php": "^7.3|^8.0",
"aimeos/aimeos-laravel": "~2021.04",
by default when I choose the arabic language, aimeos displays the numerals in arabic too, but it is arabic numeral is not used by all arabic countries (٠١ ٢ ٣ ٤ ٥ ٦ ٧ ٨ ٩ ), it uses latin numbers (123 ..).
i want to use arabic language and latin numbers (123 ..)
thank you
Re: Use arabic language with latin numbers
Post by aimeos » 20 Apr 2021, 10:30
This is automatically done by the browser and the option to use latin number seems to be to change the templates and define
dir="ltr"
explicitely for all numbers:
https://www.w3.org/International/articl ... di-markup/
mahmoud
Post by mahmoud » 22 Apr 2021, 02:32
I think this
dir="ltr"
can not solve the problem .
Because when i type:
 $priceItem->getValue() ;
===> 9999.99
But when i type:
$this->number( $priceItem->getValue(), $priceItem->getPrecision() ), "$currency" )
===> ٩٩٩٩.٩٩
i want to acces to the function number(. where is ?
thank you
Post by aimeos » 24 Apr 2021, 09:23
The number view helper is available here:
https://github.com/aimeos/aimeos-core/b ... Locale.php
There's also another one available:
https://github.com/aimeos/aimeos-core/b ... andard.php
You can change it overwriting this method:
https://github.com/aimeos/aimeos-larave ... #L161-L170
And then in a Laravel service provider:
https://github.com/aimeos/aimeos-larave ... hp#L92-L94
mahmoud
Post by mahmoud » 24 Apr 2021, 22:21
Thank you
Post by aimeos » 27 Apr 2021, 06:42
We've simplified that in aimeos/aimeos-laravel:dev-master and added a new config setting for the ./config/shop.php file:
	'num_formatter' => 'Locale', // locale based number formatter (alternative: "Standard")
If you checkout the master version, you can change the number formatter by adding:
	'num_formatter' => 'Standard',
Can you check if that works for you?
mahmoud
Post by mahmoud » 27 Apr 2021, 22:46
I checked this parameter it working perfectly!
Thank you
