postgresq syntax error
mahmoud
Post by mahmoud » 20 Apr 2021, 12:07
in the fil:
ext\ai-laravel\lib\custom\setup\CustomerRemoveConstraints.php
error syntax:
ALTER TABLE "users_address" DROP FOREIGN KEY "fk_lvuad_pid"
the correct syntax :
ALTER TABLE users_address  DROP CONSTRAINT fk_lvuad_pid RESTRICT;
thank you
Re: postgresq syntax error
Post by aimeos » 21 Apr 2021, 06:27
Thank you for pointing out. Can you please create an issue in the https://github.com/aimeos/ai-laravel Github repository?
Post by aimeos » 24 Apr 2021, 08:45
