Manually adding customers with own product
goransabo
Post by goransabo » 27 Apr 2021, 14:51
Hello!
One big problem. Current page/shop is on wordpress/woocommerce
Only what I need to do, is manually adding product with subscription, to each of customers. How to I add it with correct data.
Product + Product subscription + correct date with interval?
Best regards,
Goran
Re: Manually adding customers with own product
Post by aimeos » 01 May 2021, 14:54
You can create an order in the frontend, select the approriate interval and set the next date in the subscription accordingly after you've executed the subscription/process/begin job controller. Make sure, you don't use a mail server configuration that actually sends e-mails to the customers (e.g. mailtrap.io is a good temporary alternative).
For customers who paid by credit card, this won't work because the payment token is missing and renewing the subscription will fail.
