JSON REST API Modifications
adityabanerjee
Post by adityabanerjee » 14 May 2021, 18:48
I want to know if I have an api for the product ie http://aimeos.test/default/jsonapi/prod ... [offset]=1
and I want to make change in this particular api. How would I proceed with it? I am not able to find any documentation regarding making change in a particular json api endpoint.
I want to return this api response in random. I want to know how would I proceed to implement this in Aimeos?
Re: JSON REST API Modifications
Post by aimeos » 16 May 2021, 12:10
If you change the product API endpoint, it will ALWAYS return random results and this is certainly not what you want. Copy the product Factory and Stanard classes into a new "Random" directory of your own extension and and use your own product manager there instead to get the random results you want:
https://github.com/aimeos/ai-client-jso ... pi/Product
Afterwards, add your new "random" endpoint to your config so it will be available in the frontend:
https://github.com/aimeos/ai-client-jso ... nt.php#L12
