thumb links to wrong product
einmaku
Post by einmaku » 24 May 2021, 11:08
I created different new products. The problem now: all thumbs of new products point the the same product page - all the content (images text price and of course SKU) is different.
So what can cause this?
Re: thumb links to wrong product
Post by aimeos » 28 May 2021, 08:04
Did you copy the products? If yes, did you upload new images? Otherwise, the images of the original product are also used for the copied ones.
einmaku
Post by einmaku » 01 Jun 2021, 14:40
Yes I copied and Yes I modified all info like images, Text, prices
Post by aimeos » 03 Jun 2021, 08:44
einmaku
Post by einmaku » 24 Jun 2021, 08:40
hi
The running version is: 19.10.4
I send you a sample in attachment
Post by aimeos » 29 Jun 2021, 06:02
Does both products have an unique URL? If not, they will both point to the first product.
If your URLs are not unique, you can unset this configuration to use the unique ID for product lookup:
https://aimeos.org/docs/2021.x/config/c ... il/#filter
