redirect to 404 page if product is not found
Re: redirect to 404 page if product is not found
Post by aimeos » 28 May 2021, 09:35
If you are using Laravel, you may use its redirect() function for redirecting to another URL in case of an error.
Post by aimeos » 03 Jun 2021, 09:08
redirect() only returns a response object which isn't sent to the browser by default. A quick and dirty solution could be to use this in the catalog/detail component:
echo redirect(...);
exit();
