How to use DB in unit tests ?
MikaelNazarenko
Expert
Post by MikaelNazarenko » 25 May 2021, 12:57
Hi)
I need to cover complicated job with unit test.
Here is my blank Test class:
<?php
namespace Aimeos\Controller\Jobs;
class OrderCommissionTest extends \PHPUnit\Framework\TestCase
	private $object;
	protected function setUp()
	public function testRun()
        $this->assertTrue(true);
There must be involved a lot of data: users, orders, order_products, base_orders etc.. I think to create the mock objects is bad idea. My idea is to fill the extra DB specially for tests and retrieve data from there. But how can I set up the extra DB for tests and use DB connection to retrieve objects in tests ?
Thanks a lot!
Packages versions:
aimeos/ai-admin-jqadm                 2019.10.6  Aimeos ai-admin-jqadm extension
aimeos/ai-admin-jsonadm               2019.10.2  Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html                 2019.10.10 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi              2019.10.2  Aimeos JSON API extension
aimeos/ai-controller-frontend         2019.10.3  Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs             2019.10.4  Aimeos ai-controller-jobs extension
aimeos/ai-gettext                     2019.10.1  Aimeos Gettext extension
aimeos/ai-laravel                     2019.10.2  Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-payments                    2019.10.1  Payment extension for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer                 2019.10.1  SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core                    2019.10.7  Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel                 2019.10.1  Professional, full-featured and high performance Laravel e-commerce package for online shops and complex B2B projects
Re: How to use DB in unit tests ?
Post by aimeos » 29 May 2021, 10:36
You can write your own setup task that adds additional test data to the database like these ones do:
https://github.com/aimeos/aimeos-core/t ... p/unittest
Beware: Chances may be high that adding additional data to existing data domains will break the Aimeos core tests.
Brendon
Post by Brendon » 12 Aug 2021, 03:50
Given that I'm fairly new to server side testing, I've read that you usually want to mock the db for unit tests, and my reaction is: why in the world would I ever want to do that ? Building a query for the db that actually works is a huge (if not the MAIN) part of the server side (especially in node, since it's not calculation heavy), and I make use of it in pretty much 95% of the requests probably.
So why ? That would make tests pointless as they would just be testing that my mock responds well to queries (which doesn't make sense). What am I missing ?
