Main content disappears on Jqadm -> products list after loading
veeran ambalam
Post by veeran ambalam » 26 May 2021, 16:40
Product lists appear while loading but disappear once the page is loaded, HTML contents within main is removed after loading, I dont know where to look or why it is removed.
<main class="main-content">
</main>
Note: I have recently added upload option but even after removed them its still not working
Re: Main content disappears on Jqadm -> products list after loading
Post by aimeos » 27 May 2021, 10:34
This is due to a JS error caused by a special character you are using in your product labels. Can you please update aimeos/aimeos-core to the latest release (2020.10.25)? This should fix the problem.
veeran ambalam
Post by veeran ambalam » 04 Jun 2021, 14:15
Thank you, fixed the issue
