How to disable the mandatory of fields
ArthurHenrique
Post by ArthurHenrique » 28 May 2021, 14:23
Hi everyone, can somebody give me a hand?
I need to disable the mandatory of fields like salutation and languages, because I wont use it in my project.
Thanks in advance :)
Enviroment:
Windows 10
PHP = 7.2
Laravel = 6.0
Aimeos = 2020.10
Re: How to disable the mandatory of fields
Post by aimeos » 29 May 2021, 11:25
Use this configuration option to change the mandatory fields:
https://aimeos.org/docs/2021.x/config/c ... gmandatory
