Full product/media control over API
JakubŽídek
Post by JakubŽídek » 09 Jun 2021, 15:23
I'm new here, so sorry if I break any rules here.
I am building a very specialized e-shop/e-warehouse and I use aimeos API for authentication, product catalogue and basically everything. I don't use a separat database.
I am able to create a new product with the API with a POST request. I get the ID, I can set a name for the product, some description etc.
What I want to ask is this: How do I handle images? Can I somehow create a media object myself, which will I then place in a product's Relationships? I understand that I cannot upload and attach an image to a product over the API, but I was thinking about this workaround (Upload an image to the /files directory -> Create a Media object in Aimeos -> Insert the file URL into the "media.url" of the new Media object -> Put the new Media object inside the "Included" field of the Product).
Re: Full product/media control over API
Post by aimeos » 10 Jun 2021, 11:15
You want to update the images using the JSON Admin API?
JakubŽídek
Post by JakubŽídek » 14 Jun 2021, 08:24
Thank you for your reply,
our AIMEOS version is 2021.04 and we run PHP 7.4.3.
I would like to manage the "media" including images without using the Aimeos backend. So through the JSONapi would be best.
Post by aimeos » 14 Jun 2021, 08:43
There's no way to upload image files yet using the JsonAdm API. If you can create a pull request with the necessary change, we will be happy to merge it into the core.
You can find the code for the JsonAdm media endpoint here:
https://github.com/aimeos/ai-admin-json ... andard.php
The methods you have to overwrite in the media endpoint are these one:
- https://github.com/aimeos/ai-admin-json ... #L576-L661
- https://github.com/aimeos/ai-admin-json ... #L281-L375
JakubŽídek
Post by JakubŽídek » 14 Jun 2021, 10:27
Thanks for the reply.
One more question though. If I manage to upload the image to the /files/ using a PHP function, can I then create a "media" object with the Json API and put the file's url into the media.url attribute?
Post by aimeos » 14 Jun 2021, 10:34
Yes, you can find the relevant code from the admin backend here for reference:
https://github.com/aimeos/ai-admin-jqad ... #L354-L407
