import attributes with languageid
akropivko
Post by akropivko » 11 Jun 2021, 11:35
Hi!
Could you please advise is there any config option to import attributes for certain languages? I guess something like languageid.
I can set language id for text using text.languageid, for example
4 => 'text.languageid',
5 => 'text.type',
6 => 'text.content',
But I'd like to set the lang id for attributes also, something like:
37 => __languageid__
38 => 'attribute.type',
39 => 'attribute.code',
As a result I'd like to have it inside Texts tab:
Laravel 6.20.27
aimeos/aimeos-core 2020.10.24
PHP 7.4
Re: import attributes with languageid
Post by aimeos » 12 Jun 2021, 06:02
It's currently not possible to import attribute texts using the product CSV importer but it's possible with the attribute XML importer: [url]https://github.com/aimeos/ai-controller ... andard.php
The XML importer are not documented well at the moment but here are commented examples so you can create appropriate files easily:
aimeos-xml.zip
(9.39 KiB) Downloaded 443 times
