installation problem
AbaddónKamen
Post by AbaddónKamen » 04 Jul 2021, 07:09
Your requirements could not be resolved to an installable set of packages.
Problem 1
- aimeos/ai-cms-grapesjs[2021.04.1, ..., 2021.04.6] require aimeos/aimeos-core 2021.04.* -> satisfiable by aimeos/aimeos-core[2021.04.1, ..., 2021.04.8].
- aimeos/aimeos-core[2021.04.1, ..., 2021.04.8] require ext-intl * -> it is missing from your system. Install or enable PHP's intl extension.
- Root composer.json requires aimeos/ai-cms-grapesjs ^2021.04 -> satisfiable by aimeos/ai-cms-grapesjs[2021.04.1, ..., 2021.04.6].
To enable extensions, verify that they are enabled in your .ini files:
- C:\xampp\php\php.ini
You can also run `php --ini` inside terminal to see which files are used by PHP in CLI mode.
Re: installation problem
Post by aimeos » 04 Jul 2021, 13:53
Your installation is missing the PHP "intl" extension.
