How do I make a custom front end?
Rineloi
Post by Rineloi » 07 Jul 2021, 06:43
Is there documentation for overwriting component headers like the stock Header?
It adds a script that isn't used, since I'm overriding the template entirely.
Re: How do I make a custom front end?
Post by aimeos » 08 Jul 2021, 12:02
You can overwrite it like the body files by copying it to your own extension and then modifying it.
