Action and method as component settings for CMS forms
niloofar
Post by niloofar » 25 Jul 2021, 19:56
Hi
I was wondering if there's an option for defining a form's `method` and `action` values in the CMS component settings?
Aimeos version: ~2021.07
Laravel version: ^8.40
PHP: 7.4.9
Re: Action and method as component settings for CMS forms
Post by aimeos » 26 Jul 2021, 06:20
You have to create a component like this one:
https://github.com/aimeos/ai-cms-grapes ... #L449-L516
The traits define the options (method and action in your case) and the init and "on...Change" methods define what happens. Finally, add a block like this which defines the form:
https://github.com/aimeos/ai-cms-grapes ... #L335-L362
