Install Error - PHP Fatal error
rasch
Post by rasch » 06 Aug 2021, 13:56
Hi Aimeos Team,
when I run composer update I get the following error:
Installing the Aimeos shop bundle
PHP Fatal error: Uncaught Error: Call to undefined method Composer \ Factory :: createRemoteFilesystem () in ... \ vendor \ aimeos \ aimeos-symfony \ Composer \ ScriptHandler.php: 213
Thank you in advance.
Best regards.
aimeos: 2019.10.*
symfony: 4.4
php: 7.3
ubuntu: 18
composer: 2
Re: Install Error - PHP Fatal error
Post by aimeos » 06 Aug 2021, 14:30
Aimeos 2019.x versions only work with composer 1.x because the composer API changed in 2.x
