home page display problem
when i Try to load the Home page from the Aimeos demo shop. the elements are not displayed correctly.
In the Attachements you can the screenshot.
- Capture.jpg (66.94 KiB) Viewed 5397 times
Re: home page display problem
The CSS and JS files are missing
If you use Laravel, check if the CSS/JS files haven't been copied to the public/vendor/ directory, maybe you've missed to execute:
php artisan vendor:publish --all
