admin panel customer country section
GülsümAkça
Post by GülsümAkça » 16 Aug 2021, 16:07
I want to be able to display only one country in the country section when I create a new user in the admin panel, , how should I do this?
Re: admin panel customer country section
Post by aimeos » 17 Aug 2021, 06:25
Overwrite this configuration in your ./config/shop.php: "common/countries"
https://github.com/aimeos/aimeos-core/b ... mon.php#L4
GülsümAkça
Post by GülsümAkça » 17 Aug 2021, 07:02
Can I do this in version 2020.10.8?
Post by aimeos » 17 Aug 2021, 07:14
No, the setting is available since 2021.07. In older versions, you have to change the customer item template from the admin backend:
https://github.com/aimeos/ai-admin-jqad ... #L347-L367
GülsümAkça
Post by GülsümAkça » 18 Aug 2021, 09:14
Solved, thank you
