Subscription Questions
Hello Aimeos,
I have 2 questions.
1.
I just read how the subscription works. I want to make sure if I understand it correctly.
When a customer has selected a subscription, the product will be listed in the "Subscription" panel.
And then, I have to set up date for the customer's next purchase (Even though customer has chosen the period) in the panel.
Please let me know if I get wrong.
2.
if I understand the subscription correctly, I would like to have a notification when a new subscription has been added.
Could you tell me how to do it?
Thank you so much and have a nice day!
I have 2 questions.
1.
2.
Re: Subscription Questions
No, you only need to run the "subscription/process/begin" job controller:ryankim wrote: 26 Aug 2021, 19:45 I just read how the subscription works. I want to make sure if I understand it correctly.
https://aimeos.org/docs/latest/laravel/setup/#cronjobs
The "subscription/process/renew" job controller will create a new order when the subscription is renewed and an order confirmation will be sent to the customer afterwards.ryankim wrote: 26 Aug 2021, 19:45 if I understand the subscription correctly, I would like to have a notification when a new subscription has been added.
Thank you for your response.
I tried the command "subscription/process/begin".
I checked admin page and It set up the next date.
So, a customer has to get an another product on a designated date.
But the subscription didn't work..
I even run the renew command and still didn't work.
Could you tell me how to solve this problem?
The subscription renew task will create a new order and update the next date only if the current date in the next date field is reached or has passed.
Yeah I understand the renew task. I ran the begin command, but order didn't automatically performed on a specified date. .
