Voucher issue
Voucher issue
Hi.
I've setup a voucher in admin according to the docs here https://aimeos.org/docs/2021.x/manual/coupons/#voucher , connected it to a reduction-product.
I can purchase the voucher, I get the mail with the code for the voucher.
But when I enter it in the Coupons in the basket, I get "Coupon is not available any more"
Looking in the db, the voucher I created is in the table mshop_coupon and seems correct
In the table mshop_coupon_code I can see the different vouchers I've bought, but all of them refer to the demo-voucher that came with the install, even though I did not purchase that one, and both that one and it's reduction product was disabled.
I've deleted my own voucher and tested the demo voucher instead, then the code is found, but now I'm getting No item found for conditions: Array ( [product.code] => demo-rebate ) as I validate the code.
What am I missing here
_____________
Laravel 8 with Aimeos 2021.10.7 + Marketplace. Setup via composer. Mac with Valet and MySql 8.0.25
Re: Voucher issue
Can you post screenshots of your voucher configuration and the configured voucher product from the admin backend?DmS wrote: 17 Sep 2021, 09:07 I can purchase the voucher, I get the mail with the code for the voucher.
You have deleted the voucher product from the demo setup and you need to create a new one now which you can refer to in your voucher configuration.DmS wrote: 17 Sep 2021, 09:07 I've deleted my own voucher and tested the demo voucher instead, then the code is found, but now I'm getting No item found for conditions: Array ( [product.code] => demo-rebate ) as I validate the code.
Here's the documentation about the voucher product:
https://aimeos.org/docs/latest/manual/p ... /#vouchers
Re: Voucher issue
Yes, I've read that, multiple times. Doesn't really help me to understand this issue.aimeos wrote: 17 Sep 2021, 19:14 Can you post screenshots of your voucher configuration and the configured voucher product from the admin backend?
-> AttachedYou have deleted the voucher product from the demo setup and you need to create a new one now which you can refer to in your voucher configuration.DmS wrote: 17 Sep 2021, 09:07 I've deleted my own voucher and tested the demo voucher instead, then the code is found, but now I'm getting No item found for conditions: Array ( [product.code] => demo-rebate ) as I validate the code.
-> No, not exactly.
At first, I created a new type voucher under Marketing->Vouchers and deactivated the demo-one.
When I created a new voucher-product, and purchased that one, the codes was generated with a reference-id to the original, disabled demo-voucher.
Then I reenabled the demo voucher and deleted the one I created, and tried with the original demo-voucher.
Now I can purchase a demo voucher, then add the voucher code from that one in a purchase, but I'm getting the error "No item found for conditions: Array ( [product.code] => demo-rebate )" for the original demo-voucher. So it's the original demo-voucher that does not work. The one I created did not work either, but with a completely different error.
- Screenshot 2021-09-20 at 09.40.15.png (110.98 KiB) Viewed 9251 times
- Screenshot 2021-09-20 at 09.40.31.png (122.76 KiB) Viewed 9251 times
- Screenshot 2021-09-20 at 09.40.45.png (120.34 KiB) Viewed 9251 times
- Screenshot 2021-09-20 at 09.40.01.png (100 KiB) Viewed 9251 times
_____________
Re: Voucher issue
There's also a video at our YouTube channel describing the correct setup:
https://www.youtube.com/watch?v=4OOrpv2bDUo
Re: Voucher issue
I've seen that as well.
I can create it and purchase it.
But when I try to use the voucher code I get in the mail, regardless if I created the voucher myself, or if I used the demo voucher that came with the install, I'm getting:
in the basket when I add the code
No item found for conditions: Array ( [product.code] => demo-rebate ) _____________
Re: Voucher issue
-not sure why, but after having run for another reason, it started working.
php artisan optimize_____________
Re: Voucher issue
Most likely you ran the Aimeos setup again, so the "demo-rebate" product has been recreated.
Re: Voucher issue
Nope. I did not.
And the demo-rebate product was never deleted, or changed, just disabled for a while, then re-enabled.
But anyways, it now works.
_____________
