Product code
CodyOwen
Product code
Post by CodyOwen » 29 Sep 2021, 11:02
Hi! Can someone tell me how to create codes for products? Please make it as detailed as possible. Thanks in advance.
Re: Product code
Post by aimeos » 30 Sep 2021, 07:46
You can use anything as code. If you get data from external sources, you should add their IDs or unique codes there.
