export orders
DmS
export orders
Post by DmS » 07 Oct 2021, 08:03
I've initiated an order export from the sales page in admin, I'm told it will be available in a few minutes
I haven't customized this at all, it's all the job files from the aimeos vendor code
The only thing I've done is to add the location for the file in shop php:
'controller' => [
		'jobs' => [
			'order'=> [
				'email' => [
					'voucher' => [
						'status' => [
							'0'=>'5',
							'1'=>'6',
				'service' => [
					'payment' => [
						'name' => 'KlarnaKco'
				'export' => [
					'csv' => [
						'location' => public_path( 'aimeos/exports' ),
But when the cron job containing /export/csv runs,
It fails with this:
Invalid controller "" in "/export/csv"#0 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Command/JobsCommand.php(54): Aimeos\Controller\Jobs::create(Object(Aimeos\MShop\Context\Item\Standard), Object(Aimeos\Bootstrap), '/export/csv')
#1 [internal function]: Aimeos\Shop\Command\JobsCommand->Aimeos\Shop\Command\{closure}(Object(Aimeos\MShop\Context\Item\Standard), Object(Aimeos\Bootstrap), '/export/csv')
#2 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Process/Pcntl.php(181): call_user_func_array(Object(Closure), Array)
#3 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Process/Pcntl.php(116): Aimeos\MW\Process\Pcntl->exec(Object(Closure), Array)
#4 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Process/Decorator/Check.php(61): Aimeos\MW\Process\Pcntl->start(Object(Closure), Array, false)
#5 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Command/JobsCommand.php(63): Aimeos\MW\Process\Decorator\Check->start(Object(Closure), Array, false)
#6 [internal function]: Aimeos\Shop\Command\JobsCommand->Aimeos\Shop\Command\{closure}(Object(Aimeos\MShop\Context\Item\Standard), Object(Aimeos\Bootstrap))
#7 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Process/Pcntl.php(181): call_user_func_array(Object(Closure), Array)
#8 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Process/Pcntl.php(116): Aimeos\MW\Process\Pcntl->exec(Object(Closure), Array)
#9 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Process/Decorator/Check.php(61): Aimeos\MW\Process\Pcntl->start(Object(Closure), Array, false)
#10 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Command/AbstractCommand.php(67): Aimeos\MW\Process\Decorator\Check->start(Object(Closure), Array, false)
#11 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Command/JobsCommand.php(69): Aimeos\Shop\Command\AbstractCommand->exec(Object(Aimeos\MShop\Context\Item\Standard), Object(Closure), 'default')
#12 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Aimeos\Shop\Command\JobsCommand->handle()
#13 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Container/Util.php(40): Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
#14 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure(Object(Closure))
#15 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\Container\BoundMethod::callBoundMethod(Object(Illuminate\Foundation\Application), Array, Object(Closure))
#16 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Container/Container.php(651): Illuminate\Container\BoundMethod::call(Object(Illuminate\Foundation\Application), Array, Array, NULL)
#17 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Console/Command.php(136): Illuminate\Container\Container->call(Array)
#18 /Users/dansegolson/Documents/code/dinsaluhall/vendor/symfony/console/Command/Command.php(299): Illuminate\Console\Command->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
#19 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Console/Command.php(121): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
#20 /Users/dansegolson/Documents/code/dinsaluhall/vendor/symfony/console/Application.php(978): Illuminate\Console\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#21 /Users/dansegolson/Documents/code/dinsaluhall/vendor/symfony/console/Application.php(295): Symfony\Component\Console\Application->doRunCommand(Object(Aimeos\Shop\Command\JobsCommand), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#22 /Users/dansegolson/Documents/code/dinsaluhall/vendor/symfony/console/Application.php(167): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#23 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Console/Application.php(92): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#24 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(129): Illuminate\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#25 /Users/dansegolson/Documents/code/dinsaluhall/artisan(37): Illuminate\Foundation\Console\Kernel->handle(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#26 {main}Process (PID "1100") failed with status "256"%
_____________
Laravel 8 with Aimeos 2021.10.7 + Marketplace. Setup via composer. Mac with Valet and MySql 8.0.25
Re: export orders
Post by aimeos » 08 Oct 2021, 16:08
What is the exact command you are executing to run the job?
DmS
Re: export orders
Post by DmS » 11 Oct 2021, 07:32
First I'm clicking on the export icon in the orders list, I select export orders
Then I run this cron-job:
php artisan aimeos:jobs "order/export/csv order/email/delivery order/email/payment order/email/voucher order/service/delivery subscription/export/csv customer/email/account" default
Either the full one or just php artisan aimeos:jobs order/export/csv default
_____________
Re: export orders
Post by aimeos » 12 Oct 2021, 16:21
The command works without problems. Do you have a white space or newline in "order/export/csv" in your crontab?
DmS
Re: export orders
Post by DmS » 18 Oct 2021, 12:37
Sorry for late reply, I had no new lines or anything in the commands, but it was something on my side, after reverting some stuff it started working locally. Still need to get it working on the stage site though, there I have no error, but no files are generated.
Thank's for your help!
_____________
