Documentation for Slick Slider
whatdaro
Post by whatdaro » 18 Oct 2021, 05:20
hi Aimeos team,
I would like to know if there is any documentation for the slick slider used by the default template theme.
I would like to know where to configure speed of slides, auto matic/manual, size, thanks.
Re: Documentation for Slick Slider
Post by aimeos » 19 Oct 2021, 06:30
The Slick slider is documented here:
https://kenwheeler.github.io/slick/
The configuration for the slider can be found here (search for "slick"):
- https://github.com/aimeos/ai-client-htm ... /aimeos.js
- https://github.com/aimeos/ai-client-htm ... -detail.js
