customer import
GülsümAkça
customer import
Post by GülsümAkça » 26 Oct 2021, 10:22
hello,
We can import customers with xml file, but we have a csv file. How can we import customer with a csv file?
Re: customer import
Post by aimeos » 27 Oct 2021, 10:10
Only customer XML import is available. If you need a CSV customer import, you should create your own job controller which uses the customer manager to import the records.
